alexander coletta
Industrial
- May 16, 2018
- 6
We have a stand by 750 KVA Generator ( Marathon Electric / Volvo Penta Power ) 900 hours of use.
MTU
Model 660RVC6DT2
Engine TWD1643GE-VOLVO
The generator will run smothly when no load its applied. After a few minutes of working with load ( even 20% of the generator capacity) the engine will shut down without any warnings of alarms. ( nor the control panel or the ECU )
For some reason fuel supply its being cut , when we monitor the ECU while working we can see that all parameters are OK and suddenly the the fuel flow drops to 0 and the engine stops , no pre alarms or alarms are shown during shutdowns , later the oil press alarm will appear , but its not related to the engine shutdown
in the attachment you will see a video of the operating parameters during operation and the shutdown , we highlited the fuel consumption , so its easy to see that while RPMs are running at 1800 suddenly the fuel consumtions drops to 0
we already check all the basics with no luck solving the problem. Since we use the generator only when there is a power failure in our city, we know that we dont have any short circuits in our equipments that may trigger an emergency shutdown.
If you have problems with file you can also dowload the video here:
any suggestions will be really apreciated!
thanks in advance,
Alexander Coletta
Maracaibo Venezuela
MTU
Model 660RVC6DT2
thanks in advance,
Alexander Coletta
Maracaibo Venezuela
