Hi All
My question is in relation to Von Misers Yield stress criterion vs Principle stress limits.
If I have a simply supported beam with a point load in the middle, should the longitudinal bending stresses in the beam be checked to priciple stress limitations or to Von misers criteria.
The reason I ask is that I thought both methods were acceptable but were just differnet ways of looking at stresses. However, when you look at the Australian code provisions, one requirement is to have s1<=0.66Fy when checking priciple stresses, whereas the other requirement is to use VM equation; s1^2-s1s2+s2^2<= (Fy/1.1)^2. Note the 1.1 is the FOS on yield.
Clearly the VM equation will give you a better answer by allowing you to accept higher stresses.( i.e 1/1.1 = 0.9 compared to 0.66) So... why would you not ALWAYS use VM equation( and in my example, with s2 value zero)???
From what I have gathered from others, it seems as though both provisions must always be checked. But at the moment I can not see why. Is there a requirement that BOTH s1 and s2 must be present on an element such that one can use VM equation?
many thanks to all of you
