vs6 pump in an intermittent propylene service
danyel231
IR
in case of an intermittent service with few start a year, what plan of mechanical seal should we use?
contamination of propylene is not allowed and pressure margin above vapor pressure at pumping temp. is very low
you would be better posting this question in pump engineering forum and ask management to remove it from this forum.
