Hi All,
I'm new into this forum so apologies if this topic was already discussed in the past.
I'm supposed to draw a control panel which would include both VSD and Star/Delta motor starter. Baaically, the operator is acting on a selector switch with SD/OFF/VSD positions. Do you happen to have a schematic or wiring diagram? I'm unsure of how to implement it given the fact the VSD only needs 3 terminals from the motor but the Star/Delta requires connectiom to 6 terminals of the same motor.
Thank you very much
Mark
Thank you very much
Mark
