I have three coax cables between a radio and the antenna
with a connector at each end and two connectors in the middle.
I know the VSWR of each cable (from the spec sheet)
Each cable is 50 ohms
assuming a 50 ohm load at the antenna end,
how can I calculate the end to end VSWR?
each cable has a spec requirement of a 1.4 VSWR.
thanks
thanks
