kodstruct
- Nov 9, 2012
- 27
I have successfully used Vulcraft 2VL & 2VLI composite decks over steel joists for floor framing systems over the past 10years. One of my colleagues is saying it's better to use shear studs on steel beams instead. Personally, I feel like it will be expensive to weld the studs for two to three story buildings. Can we just use Vulcraft VL composite deck on steel beams provided that we specify the puddle welds? I've always felt like using the composite deck (VL or VLI) with specific puddle welds is enough for partial composite action after checking the requirements.
Note, my floors are always 5.5" total thickness.
Thanks.
Thanks.
