thread89-141793 Some engines are prone to making sludge. It is in the design. It seems to be in the PCV system design. What appears to happens the oil oxidizes, turns to sludge and can't be pumped, therefore failing the engine. Best solution is to use synthetic oil and change often. The important thing is to change often. I've known engines that missed a 3k mile oil change and failed.
