I daily drive two cars with either of the engines and must say that ea288 consumes way less fuel even though it is isntalled in tiguan where ea189 is instaled in A4.
Here is VW self study program for either of the engines.
what i see they both have same bore and stroke, similar compression, bot have 4 valves per cylinder, both have VGT, spark plugs with cylinder pressure sensor, both use high and low EGR, both have 16V, ea 189 have fill and swirl chanel on the intake while ea288 have vavle configured in the way that on the same camshat there are 2 intake and 2 exhaust valves per cylinder. the intake channels are thus shorter and longer what contributes to vertical swirl. Ea288 even has VVT but mainly for emission purposes - high pressure EGR. EA288 even has SRC while EA189 has only catalitic converter and PDF.
Main plus I see for the ea288 is exhaust manifold integrated into the head what warms the car quicker and thus boosting cold start fuel efficiency.
What i don't get is where does ea288 realy achieves better milage.
