W.E Sykes Gear Hobber Taper/step problem
younggun2020
5
Im currently trying to get a W.E. Sykes gear Hobber back in action and can get it to cut the required gears but it is cutting at a .005" taper/step.
I think I just need to offset one of the cutter heads but am unsure how to adjust it.
Im fairly a newbie to this machine so any advice would be appreciated.
Thanks for getting back to me.
You're right I meant that it was a herringbone gear shaper.
Im using it to cut helical gears but this taper/step is starting to annoy me lol
I'm not sure what you mean by "taper/step".
I think I understand the 'taper' part but can't work out what you mean by "step".
Is the machine not cutting the correct helix angle or is it cutting a taper to the tooth form; where the tooth thickness changes over the length of the face width?
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
It's either a taper or a step over the width of the gear.
It seems to be that when the right cutter is cutting the right half of the gear, it isn't cutting as deep as the left (0.005" of a difference in root diameter from the right side to left)
Im sure that if I am able to adjust the right head, this should work.
