Gus14
- Mar 21, 2020
- 194
I Know that two way ribbed slab works by distributing slab loads to hidden interior beams ( bands ) that carry the load to columns this is easy to design manually for irregular columns layout. However, I don't understand how a waffle slab ( without interior hidden beams ) works. I know the Direct design method, but I don't understand how loads work their to columns. So what is the load path to columns ? and how to design it for irregular columns layout manually and check long term deflection ?
