I'm designing an influent 60" diameter emergency force main that operates at 28 psi for a wastewater treatment plant. 40 psi is the specified operating pressure. It will tie in to a 60" section of an existing force main.
A 60X60 tee will be installed where the new line will be connected. The present consideration is to install gate valves at the upstream side of the mainstream section of the tee and at the tee. Plug and ball valves are being considered. Suggestions will be appreciated. Is there a 60" three-way ball or plug valve that can handle this function?
The flow will contain a lot of grit and trash.
