swazimatt
- Aug 19, 2009
- 276
I would like to know what the standard modelling procedure is for PWWF, PDF and ADF for wastewater. My understanding is that PWWF is for an hour in the morning and evening, but how would i model the rest of the day?
We have a pumpstation proposed where the receiving network can only accept about 50% of the peak wet weather flow so the pump will discharge at 50%PWWF and the balance will be stored and pumped as the flow into the pumpstation reduces down to average flow.
Is there a standard document i can refer to where it says under wet weather flows, peak is expected to be for 1hr, the flow will then reduce over x hours until it achieves ADF (or average wet weather flow?) this way i can determine the size of the additional storage tank and also demonstrate that it will clear before the next peak 12 hours(?) later
