wespark
- Dec 2, 2004
- 1
I have 2 questions. My company has purchased an environmental nightmare. It's a wastewater treatment lagoon with no process control other than chlorinating and de-chlorinating. We are meeting our permit requirements- "barely". Our problem is ammonia and phosphorous removal. The plant has no aeration or pH control. The pH stays between 7.0-7.8ppm. What could I do to decrease the ammonia - nitrogen & phosphorous levels. We usually stay around 1.8 ppm and sometimes as high as 3.0ppm. Breakdown chlorination isn't a good idea.
The chlorination contact chamber lies in a flood plane. If we get 2-3" of rain, the nearby creek actually submerges the chamber. I have since had a concrete block wall built around the chamber approx. 32" high. Well, with hindsight being 20/20, when the creek rises it may not submerge the chamber but the final effluent pipe that discharges into the creek will be submerged. I'm now thinking that the effluent flow will not overcome the creek and the creek will backup into the wall. At 32" the head pressure would be approx. 6psi. The effluent has to flow approx. 300' to the final discharge point at the creek. Would 6 psi be enough to prevent a backup and allow the effluent to flow ? Any suggestions ? I have thought that by adding vertical piping at the final discharge approx. 26-28" high may help but chances are this would likely become submerged,or if not, decrease the likely hood of the effluent flowing at all due to friction loss. Sorry so lenghty, but if anyone can help I would definitely appreciate it. Thanks.
