Water Distribution Modeling Software 2
feiginfam
My office is interested in purchasing software to run a water distribution analysis... I am trying to research and do comparisons on the ones I've found so far - KYPIPE Pipe2008, WaterGEMS or WaterCAD from Haestad, and the free EpaNET... Are there any others I should consider? Does anyone have any recommendations? We will not be using this software very often.
If your not going to be using it often, how could you possibly cost justify anything other than EPANET?
And, why would you want to?
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
EPAnet is free, it does everything I need in modeling.
I have built models with thousands of pipes and used a majority of the features. True the purchased products have fancy gizmo's to make data entry easy, automated fire flow calculation. EPAnet has a similar systems but require a little more thought.
Just the other day, I was working with a small system, and in less than a hour I assembled a model with 30 pipes, time functions and fire flow calculation. I do not see how spending thousands of dollars can pay for itself.
Hydrae
Thank you for your responses. After reading through more threads and discussing with my boss, we have decided to try the epaNET - I don't think we need all the bells & whistles, and this program should do everything we are looking to accomplish. I appreciate your honesty!
feiginfam,
I´m work to design a air distribution pipes for aeration devices used at wastewater treatment plant and would like to have a pdf format for the crane #410 technical paper. Could you inform how I can get it?
Buy ome. Scan it and convert it to pdf.
BigInch
Could you inform some web address do buy it? I´d appreciate
