i am facing a problem of knocking in down stream of float & thermostatic trap intermittently even heat load is more or less remains steady. what can be the probable reasons?. we have measured the pressure down & up stream of trap. as per the design of trap it is ok. chest pressure of heat exchanger is more than ( sufficient based on pressure drop calculation for condensate flow) the condensate header pressure.
