Water injection-
I received a DOE grant in 1980 to build an alcohol still and convert a car to run on straight alcohol. I made 160 proof alcohol and purchased 200 proof to run tests with the car. After tuning the engine (modified to run on alcohol) I ran tests on 200 proof, 190, 180 and 170 proof tuning for each mixture.
I found that in 1/4 mile acceleration tests, (3 each) there was very little difference between the 200 proof and the 170 proof runs which puzzled me as I had displaced 15% of my fuel with water in the 170 proof.
It was suggested that the water in the 170 was going into the combustion chamber as a liquid and turning to steam which replaced the 15% heat expansion from the fuel burn thus maintaining the power. Even though it lowered combustion chamber temp it still performed the same. I suspect that the steam expansion out performed the gas expansion.
This made me install a aux water injection system on two 318 Dodge engine trucks and run the same tests and they also produced more power then just on gasoline.
It was noted that the engine in poor condition raised in power more then the good engine.
I made no fuel mileage tests.
