From marketing literature, GE offer water injection, steam injection and Dry Low Emission options on several turbines for engine mounted NOx abatement. These include the LM1600, 2500 and 6000 in all of the arrangements.
“The LM6000 Sprint™ System is composed of atomized water injection at both LPC and HPC inlet plenums. This is accomplished by using a high-pressure compressor, eighth-stage bleed air to feed two air manifolds, water-injection manifolds, and sets of spray nozzles, where the water droplets are sufficiently atomized before injection at both LPC and HPC inlet plenums.”
“The introduction of steam or water into the combustion system:
_ Reduces NOx production rate
_ Impacts the gas turbine performance
_ Increases other emissions, such as CO and UHC
_ Increases combustion system dynamic activity which impacts flame stability
_ The last item results in a practical limitation on the amount of steam or water which can be used for NOx suppression.”
“GE’s current, guaranteed minimum NOx emission levels for various control options. With steam or water-injection and single fuel natural gas, the LM2500 can guarantee NOx emissions as low as 15 ppm. For applications requiring even lower NOx levels, other means, such as selective catalytic reduction (SCR), must be used.”
Also search Solar Turbines for such information or details specific to your interest.
John
