Interestingly enough, the stock pump with the cast impeller did seem to perform more reliably at low rpm. I have some suspicions that the edelbrock pump is made for those in mind that idle their overcammed engines at 1500 rpm.
To enhance the story some more, the motor is in my 1971 ford LTD and I am using it tow a 30' 6500# holiday trailer. Ironically as long as I am moving or on high idle everthing is fine from a cooling aspect. Only when I am jockeying around in a camp spot is the overheating occuring. This is what leads me to believe that fancy pump I just bought is not pumping adequatley at low rpm. I think I will hunt down a pulley that is smaller for the water pump, therefore increasing the base rpm of the pump and bladed fan, leave the crank pulley alone, since it runs the ps pump too. I will add a clutch fan if I can hunt one down. I may also switch from the 1971 steel fan to a 1976 steel flex fan of a newer LTD. The thought on the clutch fan is to return extra HP at highway speed / cool conditions. The clutch should lock up during any hot operation provided water flow is happening and the rad is hot.
Any clever folks out there know how to make a RTD work on a DVM with a minimum of parts? i.e. an op amp / resister network? I haven't gotten to installing a proper water temp gauge yet. (yeah yeah I know, I have just been busy . . .)
I would love to finish edelbrocks work by installing a flow meter in the radiator hose, any smart ideas to measure flow in a rad hose for cheap. A 1.5 inch magmeter would be sweet but $3K is a little rich.
a household water meter might work, but I don't have one and am not too sure how well it would deal with 100°C coolant.
