hopson175
- Sep 1, 2016
- 3
We are having an ongoing discussion related to the use of a vertical chamfer strip at construction joints in water retaining structures. This would look like a typical contraction joint without any interrupted reinforcement. There is a PVC waterstop cast into the construction joint.
I am in the midwest and have never seen this practice used. We have construction crews up this way from the south and apparently it is used in the there quite often and they are adamant it is required.
I do not like this detail as it reduces the concrete cross section and reinforcement cover at the joint, which to me is not desired in a water retaining structure wall designed as a 2 way plate. These structures have been designed using the most stringent min T&S reinf of .005 per ACI 350.
Is anyone familiar with this practice in water retaining structures?
Advantages to using this detail?
Disadvantages to using this detail?
Any thoughts or feedback would be appreciated.
