Yousef ZAA
Is there any tension stress limit on water tank wall (Liquid Containing concrete wall), the tension from 0-50 cm of bottom of wall is -3 MPa and then from 50 cm to it's full length(5.5 m) the tension is -1 MPa and the fracture stress is -3.5 MPa is this stress (-3 MPa at far end of the wall 0.5 m and then the stress is better)permitted in ACI, we are talking about a water tank wall it must have a tension limit
