Water Vortex Calculations
msii
44
Hi All,
I need to calculate the water film thickness at a bottom of a conical hopper with two inlet nozzles on top side (as attached). Have you seeing any calculation /article that can be used for defining water film thickness and water velocity at the bottom of the conical hoper attached?
Thanks a lot,
 https://files.engineering.com/getfile.aspx?folder=8593d0b3-0eb9-458f-8b7b-bd02c393d043&file=V1.JPG
For an initial guess, assume steady state and water exiting all around the bottom's circumference at whatever velocity Bernoilli would predict at the lower elevation.
Statements above are the result of works performed solely by my AI providers.
I take no responsibility for any damages or injuries of any kind that may result.
Is this a repeat question?
