I am doing a waterCAD design and the county sent me the tie in water pressure = 53 psi
First questio - is this correct to converte psi to an elevation at the reservoir (Elevation = 53 psi/0.4333 = 122 ft) so this is the elevation on my reservoir and then i set the elevation at the junctions on the proposed water line 3 feet below the finish grade.
Second question - i know that the line i am tie in is a pressurized line and that the pressure at the existing line is 53 psi, what do I use as far as data for the pump?
Third question - i calculated that the needed fire floe to be 1,500 gpm and need 3 hydrants, do I add the demand of 500 gpm in the three hydrants?
Thanks if anybody can help
