We are about to carry out tightness test of a Diesel Hydrotreater reaction section for newly constructed plant. The op.pr. is 125 kg/cm2 range.
To carry out tightness test of this system with NITROGEN, Make-up gas and Recycle gas compressors can provide max upto 42 kg/cm2 g pressure because of constraint on discharge temp with higher disch. pr. The valves on compressor for nitrogen service are also not designed for higher pressure.
We are planning to carry out tightness test with Nitrogen upto 42 kg/cm2 g pr. and then inject Hydrogen to carry out tightness test upto about 100 kg/cm2 g pressure.
However, our client is asking us to carry out tightness test with NITROGEN up to 100 kg/cm2 g pressure which is not possible with the compressor in the plant.
I would like to know if someone has an exp for carrying out tightness test with Nitrogen under these conditions. Is it really required to carry out tightness test above 42kg/cm2g pr with nitrogen?
Thnx in adv.
Nirav
Thnx in adv.
Nirav
