Haf
- Nov 6, 2001
- 176
I have a unique application that essentially boils down to a cantilevered beam with a load acting perpendicular to the end of the beam. The unique part of the problem is this: we want the beam to be stout with the load acting in one direction (let’s say downward), and we want it to fail with the load acting in the other direction (let’s say upward). The cantilever is made of steel and is rectangular in cross section.
Our concept is this. We’re thinking of making a thin cut (using a 0.001” thick EDM wire) near the base of the cantilever. The cut would be perpendicular to the beam and would start at the bottom and move towards the center of the beam. At the end of the cut we would make a circle with the wire to reduce stress concentrations. So, looking from the side, the cut would look kind of like a lollipop. If necessary (and feasible), the thin cut would be filled with shimstock.
With the load acting downward, the part of the beam that is cut will be in compression, so our hope is that the effects of the cut being there will be minimal. This, of course, implies that the cut must be well on the compression side of the neutral axis. With the load acting upward, the part of the beam with the cut is in tension, and we essentially have a thinner beam. Also, we have a nice stress concentration at the end of the cut that will help with failure when the load is acting upward.
One complication is that the load is acting dynamically (think of hitting the end of the cantilever with a sledgehammer). That means there will be shock waves and rarefaction waves running around.
What are your thoughts on this concept? Its simplicity is driving me nuts. I can’t help but think there’s a “gotcha” somewhere!
Thanks,
Haf
Note: this question was also posted in the "Stuctural Engineering other topics" forum.
Thanks,
Haf
