HungryDinosaur_imported
Marine/Ocean
Hi All,
One of the workshops I visited had a lifting beam and web slings. The lift beam is made from a I-Beam. The web sling has been wrapped around 1 or 2 times as the sling is long. Can you please advise
1. Is wrapping of a web sling permitted around a I-Beam, even if the edges on the beam are protected?
2. Is there any edge radius limitations on the web sling?
I am more keen to refer to a standard which specifically mentions this. Anyone can guide me to the particular standard if there is?
Thanks in advance.
HD
Thanks in advance.
HD
