CBSE
- Feb 5, 2014
- 309
I have a decently unique project that we are trying to figure out loading conditions for. We are designing the structural "shell" for a firewood dryer. It is rectangular in nature, about 30ft tall, 10ft wide, and 20ft long. It will all be built out of steel.
Question: Anyone have any ideas on how to estimate the lateral forces from the firewood stacked in this thing? The firewood gets dropped in from a conveyor at the top and then just piles up inside.
I first thought about using the equivalent weight as compare to water, assuming douglas fir and a specific gravity of 0.50. This seams conservative though because there are an abundant amount of internal frictional forces at work here. The total weight of wood that this can hold is around 120,000 lb. This equates to about 20pcf of material inside. Would that be a reasonable volumetric weight to assume? It seams big though when calculating the pressure at the bottom of the box...600 psf.
