We have a button that General Motors created (So I cant change it). I believe it sets the reference sets on the part you are in. We use it after making new details and such.
The button still does the job and seems to work, but after running it on a detail, if you go to the Assembly window, that detail acts strange. If you hit the check box in the assembly navigator to turn it off, it still shows in the assembly. Whether you have it on or off, if you try to select it from inside the window, it is unselectable.
We have checked layers, visible in view and reference sets and everything. The only way to fix it is to close the detail and re-open it. Then everything is back to working perfect.
Has anyone else had this glitch or something similar to it? Have you found a way to fix that?
