Oct 29, 2007 #1 cerati Mechanical Sep 2, 2007 6 0 0 CL Hi all! I would like you to tell me how to weld FEMs which belong to an assembly fem... I've read a thousand times the manual but I cant make it work.... fem connector points, lines... I'm really dizzy... Thanks in advance Cerati
Oct 31, 2007 #2 NastranQ Automotive Sep 3, 2007 19 0 0 RO Do you want to know how to add the FEM's of diferent parts into a sigle assembled FEM? If so you need to create an assembly from the parts who's FEM's you want to assemble and then you need to create a FE model and define the assembly FEM. Upvote 0 Downvote
Nov 9, 2007 Thread starter #3 cerati Mechanical Sep 2, 2007 6 0 0 CL Nop. I have an assembly fem already. I went to "define connectors" on meshing to create a line connector which is suppossed to be used for welding. But I can make it work. There is some "lengths" you have to specify, and everytime I "generate"the weld, it fails. Help! Upvote 0 Downvote
