Weld Flange To Dish Head Directly
wcw1985
44
Dear All,
I have 1 question which cannot be solve and would like to ask for dear forum members's opinions:
Design condition:
Internal pressure : 10 bar
Torispherical Dish Head: OD1300mm ( around 51")
SORF 20" Flange Ansi 150 -->OD about 700mm (27.5")
I would like to open an opening in center of the dish head and weld this flange directly on it using welding method just like Fig UW-16.1(c) without any nozzle.
How do i calculate to know if the opening is properly reinforced?
I checked UG-36 (b) (2) but i see none of the figure in Fig UG-36 similar to my case.
I checked Appendix 1-7 (LARGE OPENING IN CYLINDRICAL AND CONICAL SHELL) but it was for opening in shell not head.
I checked Appendix 1-10 (ALTERNATIVE METHOD FOR DESIGN OF REINFORCEMENT FOR OPENING S IN CYLINDRICAL AND CONICAL SHELLS UNDER INTERNAL PRESSURE) still was for shell not head.
I really hope for a reply that could help me. Thanks in advance.
The flange will be closed with blind flange in the end of the fabrication.
doct9960,
1st: To cut cost. I may be suffer from engineering calculation initially but if i can cut cost by saving the cost of the project, i will try my best to do it.
2nd: The bottom of the tank required a manway because there is a baffle plate near the bottom of the tank which to be bolted with some bolting equipment require human to do servicing ( unbolting the nut from the bottom of the tank) in the future.
3rd: It does not require U-stamp by the client but the local government require us to submit a valid calculation based on ASME code in the fabrication of this vessel.
4th: This vessel will go many places (a lot of units in the future) but particularly in the asia like singapore,indonesia,malaysia, and thailand.
wcw1985, I don't see how you could consider a, say, 6" long piece of pipe to be more costly than your various schemes to seal the flange bolt holes.
Mike
Hi Mike,
The way to seal the bolt hole is an idea only,after long discussion in this forum ultimately i think cutting a plate, drill and tap hole would be more practical and faster than sealing a bolt hole and using flange. I would like to thanks gr2vessels for his idea.
wcw1985,
The following are pressure vessel regulations stipulated in current codes:
Plate cannot be used for the size of your flange, it has to be a forging, fully tested in fabrication. You have to design the flange as per ASME VIII-1 Appx. 2 or similar code. You cannot drill through the flange and tap the hole, exposing the thread to the internal pressure. You must design it with a minimum thickness under the bolt hole to withstand the design conditions. In other words, you have to reinvent a standard flange, called studding outlet. You might make it a bit thinner and lighter, based on your particular design conditions, but the cost of fabrication will make it impractical.
Cheers,
gr2vessels
Why would you not use a Std or Long RFWN Flg and be done with it.? That would be very cost effective and realtively easy to install with plenty of advice/guidance from Sect VIII. If there is no room beneath the vessel, I would suggest that you lengthen/strengthen the vessel supports/saddles to allow human ingress/egress. Any anncillary piping connecting to the vessel can easily be adjusted to accomodate a taller vessel.
It concerns me that you are in a jurisdiction that allows pressure vessels to be manufactured without U stamp certification. There is a reason for U-Stamps and there is a reason for codes and recommended practices: They save lives. Why try to change or go around years and years of knowledge/experience.? Cost saving..?? Cheap products are just that, CHEAP and 99% of the time not worth the money spent. In this case potentially deadly.
You came here for opinion, this is mine.
Build it right and promote that fact.
stk
