JohnWeal
- Dec 16, 2012
- 124
We have 4 pipeline sizes (700, 800, 1400 and 1600mm) and I was wondering what is the exact inside diameter.
The pressure is no more than 5 bar so only need a Standard wall thickness of 9.53 (0.375")
According to EN 1092-1, the weld neck flange bore shall taper at 15 degrees. However, also to consider is that the 'SP' dimension (adjusted wall thickness of the weld neck) is still thicker than the 9.53 pipe wall.
There are some other criterion but in a nutshell, what must the outside diameter of the pipeline be? I'm assuming it is the same as the weld neck flange and it is the bore of the WN flange that changes. Just a little confusing as the reduced wall thickness of the weld neck is 14.2 but the pipe wall is 9.53.
Appreciate any help.
John
John
