I am designing a heat exchanger (nuclear) where I have tubesheet circulating around the shell.
Tube sheet is connected to shell using filet weld. Part of the fillet weld also passes from through the longitudinal seam creating weld on weld situaition.
Vessel is designed to ASME VIII Div.1 and what I was propsing was to do NDT examination (dye pen) at the cross joints ??
As this vessel is to be used in nuclear I am bit worried as is it a safe route on weld examindation and is this method acceptable to ASME.
Thanks for reading and advice are greatly appreciated.
