Tmoose
- Apr 12, 2003
- 5,633
we are having some big castings made in ductile iron. To support some large internal cores the foundry prefers to use steel "chaplets" that pass thru the casting wall and protrude to the inside and outside. The chaplets are ground off and weld repairs are made. Welding this material has sometimes proven difficult without cracking, and even when the welds are sound the effect on metallurgy is always suspect. The operating stress is completley unknown, so objecting to welding on that level lacks teeth (as does NOT objecting).
Is there some other method of core support?
