durablack2
Automotive
Should weld repairs be conducted before or after initial heat treatment after casting? I am seeing mixed messages from sources I find online and from different regulatory agencies and it is not really defined in the ASTM standards I am reading. I am mainly looking at ASTM A27 and A148 but believe this should be true for all steel castings.
So anyone know what the answer is according to casting standards? Should it be according to process A or B below and why?
A) Cast - weld repair - heat treat
B) Cast - heat treat - weld repair - post weld heat treat (if necessary based on grade)
