Weld repairing a Quenched and Tempered cast steel
theedudenator
I have a steel casting that is quenched and tempered and then machined
Weld repairs were performed after the machining.
I am assuming the casting should be re-heat treated.
Is it typical to just re-temper? or a full Q&T?
Is there a time frame to complete this after the welding is performed?
Are there any specs or standards I should be looking at?
Any specific tests/analysis to check the welds?
tc7 please refer ASTM A148 which defines minor and major weld repairs . Based on this 25% wall thickness is recommended.
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
