Oct 27, 2022 #1 JohnRwals Structural Jul 8, 2020 146 0 16 US Hi! Can I weld coil nuts to the plate to make precast concrete connections? JRW
Oct 27, 2022 #2 Greenalleycat Structural Jul 12, 2021 507 0 0 NZ This needs a bit more context You -may- be able to do so, but be very careful - some types of bolt steel (including nuts and washers) is NOT weldable and you will irreparably degrade your connection by welding the wrong types of steel Upvote 0 Downvote
