gte447f
- Dec 1, 2008
- 820
I have a situation where I need to weld a nut to a beam web to receive a threaded rod "thru-bolt" that will transfer tension/compression forces from the threaded rod to the beam web. One side of the beam web is not accessible, so a double locking nut arrangement is not possible. The threaded rod will be A36 steel. What nut material should be specified that is both compatible with the A36 threaded rod and weldable? I understand that high strength (i.e. heat treated) nuts should not be welded. Is this all a A563 nuts, or are there some grades of A563 that are weldable? What is the proper designation for nuts made from A36 steel if there is one?
