Alfonzo
- May 29, 2009
- 2
Hi Guys,
I have a welded structure that comprises of a 12mm thick 6082 Al Alloy plate welded to a 2" dia. x 16swg tube. Because of the large difference in sectional thickness, our guys had to put a lot of heat into the plate prior to getting a decent TIG weld. The plate forms a lifting eye by which the structure is suspended by, so we are worried that the now annealed softer al alloy may not be quite man enough for the job (the 2" tube). We've decided to add some additional welded gusset plates (prob. 3mm thick) to help share the lifting loads along the 2" tube, and in order to get some welds in shear. TBH, the design could have been a lot better, but too late now. Question - having heated the al alloy once during the intial welding procedure, will the strength degrade further from another bout of heating and welding, or is it (as I believe) a case of the damage was done first time round, and it will stay the same through repeated heating?
