Hajakala
- Mar 23, 2017
- 16
Hello. I have a thin flat square shaped container that is welded around the edges and filled with water.
After welding it induces tensile residual stress approaching the material's yield strength around the weld seam.
When I pressurise the vessel to more than 2 bar, what is going to happen?
Will the maximum allowable stress value according to section 8 of asme code be: tensile residual stress + applied 2 bar pressure?
I am not sure how to model in abaqus and what to look for when checking if the component is safe when pressurised after welding.
Could anyone please tell me the correct approach and how to go about modelling this? How can I tell if it is safe? Which field output should I look at? Like Peeq pemag? Should I look at ductile damage using Gurson? The operating temp is low and its ss so i dont think creep is an issue.
For now I have modelled the welding process and then just pressurised the component in the next step. Now I get very high direct stresses way above the yield strength.
Thanks.
Thanks.
