22west
- Oct 31, 2002
- 80
Has anyone had any problems welding A514 and A572?
A514 is a 100,000 psi material and
A572 is a 60,000 psi material.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Danzer said:Never have a temperature over 500° if you hope to maintain the 100ksi strength of A514. Yes controlling pre heat and post weld cool down is important, but not super critical.[/quote Danzer]
I believe I addressed this in an earlier post as interpass should NOT exceed 450 deg F. Preheat should not exceed 150 deg F. We are in agreement up to your last comment not being supercritical, there is no such variable. You have essential variables in welding, in my humble opinion interpass and preheat are essential variables for high strength materials.
Danzer said:We weld a lot of high strength heat treated steels used in logging and construction. The best results are with an E80SD2 solid wire with 75-25 shield gas for most temperatures.[/quote Danzer]
I only dealt with the SMAW process as an example, your filler metal above is acceptable to me.
Danzer said:Why would you use A514 if you didn’t need the 100ksi strength? We have seen many places where welding high strength materials with lower strength fillers end up with fatigue cracks in the center of the weld.[/quote Danzer]
I believe I had asked a similar question in an earlier post. Lower strength fillers metal or under matched filler metals serve their purpose, and must be considered in suitability for design.
