Welding Allowed maxium oscilation in SMAW vs GMAW
JBCZL
ES
Why in SMAW process the maxium oscilation is 3 times the electrode diameter and in GMAW process is 8-9 times?
Ussually SMAW diameters: 2.5, 3.25, 4 and 5
Ussually GMAW diameters: 1.2
I think the answer is in ASME CODE (maybe IX), but I can not remember where
Many thanks
It isn't.
It's one of those wives tails, like the one about driving moisture out of the steel before welding it.
Best regards - Al
Where can I find these limits? I think in ASME IX there are, but I do not where.
Many thanks
No weaving limits are listed in ASME IX. That is the wives tale part.
The limitations for prequalifcation for AWS are found in AWS D1.X , i.e., D1.1 for structural steel, D1.2 for Structural Aluminum, etc.
Best regards - Al
Oscillation is not a variable for the SMAW process. Are you referring to a weave bead technique, as opposed to a stringer? It is often stated that the weave bead should be no wider than three times the electode diameter. That is a common industry practice, but it is not in the ASME IX Code.
Joe Tank
