Hello all. Is it okay to field weld anchor bolts protruding through holes?
So I have a situation that required installing anchor bolts first, then field weld an unequal leg angle to the anchor bolts. Say I am using an unequal leg L4x8x1/2, with the long leg being vertical. I am installing 4 anchor bolts, then 4 holes would be drilled through the 4" leg, with the 4" being horizontal. Then I will weld the anchor bolts, with the shanks protruding through the 4 holes. Then I would plug weld the holes. Next I would inject high compressive strength grout from the near side and from either side of the end of the angle. My question is: would the plug weld be possible, with the anchor legs protruding through the 4" horizontal leg? I do not have a sketch but if you guys needs it. I can draw it up and post it later. Thank you in advance. Have a great weekend. Cheers.
