metootoo
- Aug 9, 2007
- 21
I'm designing a receptacle using A106 B 24" sch 60 pipe. The ID will be machined for a very close fit to what goes inside (.01" gap). This pipe the be welded to a large plate. I'm trying to figure out the minimum length to make the pipe such that the welding will not effect the shape/size of the machined area on the other end of the pipe. Is there a rule or formula to determine this?
FWIW: 24" sch 60 = 24" OD x .969 wall
