Welding of HSS to HSS
EngDM
698
I'm working on the connections in an HSS truss, and I am spot checking with Risa connection when I noticed that, if the width of your branch member width + 2*weld D exceeds the workable flat of the HSS chord, it doesn't allow you to proceed with the calculation. I've screenshotted their report below:
However, we have received structural steel shop drawings (when we are EOR) where the weld does not pass this same check, and fillet welds are still used all around.
Realistically I could groove weld the branch to the chord, but I know I've seen fillets used even though they don't "pass" this check which are much more cost effective.
I think it is a best practice thing, I am not a big fan of RISA connection software, some of its error outputs are difficult to investigate or resolve.
Agreed. Hunting down their references is a nightmare. Especially for CSA references, where the page they reference isn't the same for the edition they are running the connection for.
