isuzu14b
Industrial
- Sep 10, 2009
- 3
I have a case-hardened gear from an automobile transmission that i have modified, however because of the modification, i now need to re-weld the two parts of the gear back together. I say "reweld" because these pieces were welded from the factory (mitsubishi) and the modification caused the weld to be machined off. Obviously mitsubishi case hardened the gear after the welding process, but now i dont have that same luxury. The outer, hardened layer of metal has been machined off at the location of the new weld, and since i would be welding the "core" metal i am wondering what results i can expect as far as strength is concerned. Also, i do not know what alloy was used to make the gears, and if anyone has a good idea of what it may be i would be interested to know. I was planning on TIG welding the pieces back together without any filler rod. During the welding process i need to keep the gear as cool as possible since i do not want to loose temper/harness. At what temperature will the temper become compromised? Someone suggested packing the gear in glass bead or sand as a heat sink, do i have any other good alternatives?
I have attached several images of the modified gear, as well as an unmodified gear for comparison.
The synchronizer cone has been machined off to accept a double-synchro assembly, as seen in the images.
Thank you very much for any information you can give me!
