Guest102023
Materials
I'm performing several routine WPQs to Sections IX, VIII-1 and B31.3, and I'm running into problems with B31.3 (where I have not spent that much time over my career). Charpy impact testing will be performed. B31.3 seems overall pretty sketchy on requirements for welding procedure qualifications, but the specific problem I am having is this:
Table 323.2.2 Note (2) references Table 323.2.1. Unfortunately Table 323.2.1 is nowhere to be seen, in both the 2006 and 2016 editions.
Is there some trick here? I can't believe the Code committee would have repeatedly missed something so obvious.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
