tranmylinh
Marine/Ocean
- Jun 4, 2015
- 13
Hi everyone,
Can you support me in welding requirements with thickness 32 mm in sphere tank following ASME VIII div 1 with teachnical specification: Material is Steel grade PT610Q (ISO 9328-6, Weldable fine grain steels quenched and tempered) Yield strength min. 490 Mpa, Tensile strength min 610 Mpa
+ Equivalent material in ASME IX (P.No and Gr.No)
+ Min. Preheat temperature and max interpass temperature
+ Post weld heat treatment ( minimum temp. and holding time)
+ Hardness testing requirement for PQR
Thank you & Best regards.
