I wanted to check to see if anyone has experience in the use of weldless, Uni-Flange type, setscrew flanges on fusion bonded epoxy coated pipes. I was considering using one on a 12in pipe exposed to steady water pressure of 85 psi with some infrequent minor pressure pulsation up to perhaps 90psi. The epoxy coating is about .050in thick. I believe these are 12 setscrew flanges. Is there any pressure test standard for which I could test this assembly and what would a typical overpressure safety factor test pressure be? Thanks,
Phil
Phil
