Patches429
Hey, newbee here... I have a 68ft deep well, 1 1/2hp submersible pump, (I know its overkill...but I own it)the surface level of the water is ~15' down & I want to place the pump at 60 ft. Will use 1 1/4" pipe to the house which is ~10' uphill from the well ~80' from the well, and continue uphill ~90' to a 3000gal. reservoir tank ~20' uphill from the pressure tank under the house. I do NOT know what the refill rate is on this well yet...During my search for a 1 1/4" pitless well adapter, I was told that the pump is to large and that it would not ??develop/maintain head pressure?? Can't recall all the clerk at the plumbing supply place told me, was hoping one of you guys/gals could give me a hand with my dilemma!! Mind you, I am not a plumber... Just a green electrician with some construction experience rebuilding an old homestead!!
