Redskinsdb21
Mining
- May 4, 2009
- 45
Hello Fellow Engineers,
I am currently working on a project to replace several power Xfmrs that are located in vaults. So an issue is whether or not the new Xfmrs will even fit in an existing vault or vault will need expanded. I have asked for preliminary quote with dimensions. However, I got to thinking if my client would liek to increase Xfmr size (KVA rating) then how much larger would the Xfmr be? So my question is, what affects the physical size the most? Is it KVA rating? If voltage levels are higher does than increase Xfmr size much or is it mostly KVA rating?
Thanks!
Thanks!
