  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
what are the recommended speeds for drilling GLARE
khalchris
33
Hi all,
what are the recommended drilling parameters ( cutting speed and feed rates ) for drilling GLARE material.
can I use similar drilling parameters used for Al2024 , any suggestions ?
I have no experience in this particular material but it contains glass fibers which are extremely abrasive. I believe you will find that HSS drills will not be able to cut this material effectively. Carbide tipped drills will probably need to be used.
Try cutting some samples before you go into production if possible.
Bill
hi Bill,
thanks for the reply, I am doing a research and I want to cover as much as possible of the drilling parameters but I don't want to use any random cutting speeds and feed rates , I prefer to have a more realistic combinations of cutting speeds and feeds.
Look at drills made for working on printed circuit boards.
B.E.
